Updating DGNLIBs
I've been working on preparing company standard feature definitions, feature symbologies, annotation groups, and text favorites.
I've been preparing these features in working files, and now I want to import them into the appropriate dgn libs. Anybody know how I can update a dgnlib with specific features from another dgn?
Parents Reply
  • answer to your first question would be no... in my working file i made copies of similar out of the box definitions, renamed and adjust where needed.
    I assume it should be that simple! How can I load my working file as a temporary library into my dgnlib?
    actually found information where i can export/import feature definitions into an xml file. still looking for a work around for the annotative style i created(text favorites and annotation groups).
  • If you go toward the bottom of the page I linked, is shows how to load a temporary library by right-clicking on the OpenRoads Standards -> Libraries heading in Explorer.
    Caveat: I have not tried this myself and I am not in ORD this week to confirm.
    If that option is not available, it's possible that there is a bug, or that the Help file is simply wrong...In that case, you should probably file a Service Ticket with Bentley Support to let them know that's a problem. While you're there, you can ask about combining your resource libraries.
    I know from watching people here that the XML option works fairly well for feature definitions. I don't know how else you would migrate the annotation-based definitions. Hopefully others here will have more suggestions.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
