I have storm and sanitary pipes displayed in a cross section set. Is there a way I can annotate them? I would like to display ID and size.
Marc,
Go to Drafting> Place Cross Section Note. In the bottom, right hand corner of the dialog, click the black arrow to expand the dialog. Under Inserts, you should see Storm and Sanitary Structures. Add the desired inserts to a new or existing note. Click the Settings button and make sure that Placement Mode is set to Element for the selected note. Click Apply on the Place Cross Section Note dialog and select the drainage structure in your cross section.
In the Proposed folder, you should see an example note called Structure and Invert.
I hope this helps.
Jason Smithey
Thanks Jason, I'll give that a try.
I have to ask the question though....Is there any talk of adding cross section annotation of drainage features similar to profile annotation? That way it could be done as an "all at once" command rather than having to go through each section and clicking on each pipe.
Marc
I searched and could not find a request for this functionality. If desired, please file a change request through: http://appsnet.bentley.com/srmanager/addcall.aspx
