Civil Accudraw In Sheet Model?
I have a simple question two users were asking me and I don't know the answer.
Say a user has a roadway plan sheet, created by ORD. it is in a sheet model. All the user wants to do is track stations in the sheet, ostensibly with Civil Accudraw.
Thing is, Civil Accudraw won't activate in a sheet model.
There has to be a way to do this that we're missing... thoughts?
Thanks!
  • There probably isn't, since Bentley has decided that sheets don't have any function at all except to print. But I'll be interested to see what others have found.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • If you are following the Bentley-prescribed method for Sheet creation, then no, it would not function. A sheet model in this case has rotated and scaled the referenced models to fit a true-size sheet. The design elements are not geographically correct nor are they the correct size.
    You would be be able to use tracking in the Default or Drawing models, however.
    Eddie Giese, PE
    Production Manager | Senior Roadway Engineer
    Licensed in FL & PA
    ACEC FDOTConnect Instructor on behalf of FDOT
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
    premier-scholar-badge road-designer-badge
