<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Exporting to Microdrainage</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/232506/exporting-to-microdrainage</link><description>Hi all, I have a drainage network within OpenSite that I want to export as a Microdrainage file. I use the export Microdrainage command and go through all the options fine. It appears to do something and I don&amp;#39;t get any errors. However, when I look in</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Exporting to Microdrainage</title><link>https://communities.bentley.com/thread/724419?ContentTypeID=1</link><pubDate>Tue, 02 Aug 2022 08:50:07 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:996a9bda-7501-4179-9061-68f63adc62e3</guid><dc:creator>Jonathan Smith</dc:creator><description>&lt;p&gt;One thing to check is whether the conduits are numbered dendreticly (i.e. 1.000, 1.001, 2.000 etc), as per the MicroDrainage / Wallingford Procedure convention. If they&amp;#39;re not, then I think that this might cause the problem you&amp;#39;ve described.&lt;/p&gt;
&lt;p&gt;If this is the case, then you can use the Branch Labelling option, on the Tools ribbon, to relabel all of the conduits. Export to MicroDrainage should then work.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
