Template (*.ITL) Component, Which Does NOT Effect the Active Terrain
Not having a large background in creating corridor templates, we are trying to build a template, which has a "sound wall" in it, as a component. However, we do not want the sound wall to influence the proposed terrain model, coming out of the proposed corridor. Basically, we want the sound wall to be present "on top" of the proposed terrain. Actually, the sound wall will be both above and below ground, counting the footing of the wall. Basically, this would be like a retaining wall, which is "retaining nothing".
I'm sure this can be done. Is there a setting for the component, within the template? Or is it dependent on the feature assigned to the component?
Any help would be appreciated.
Parents Reply Children
