I'm having trouble getting components to display in my corridor. The linear features are all there, but only have components on the right side. I'm still new to OpenRoads (2020 Release 3 10.14.04.04) so I'm not sure what's causing this; probably something simple. Any help is appreciated. Thanks in advance!
Check to see if you have component name over rides defined for all your components. If so, try and remove them and sync the corridor template with the ITL.
Marc
Answer Verified By: Jean Mouton
That did it! Thanks! So I'm guessing I need to name components on each side of the road differently, i.e. "left surface", "right surface", etc.?
Exactly. We use a -LT and -RT suffix for point names and component names. We also add a -M for a median component or point that also has an outside complement. And a -F or -B for Front and Back for things like sidewalk edges. Sequence numbers are for the birds. It's hard to get consistent breaklines with sequence numbers. A tight naming convention makes transitions easier and modeling a smoother process.
