I'm having trouble getting components to display in my corridor. The linear features are all there, but only have components on the right side. I'm still new to OpenRoads (2020 Release 3 10.14.04.04) so I'm not sure what's causing this; probably something simple. Any help is appreciated. Thanks in advance!
That did it! Thanks! So I'm guessing I need to name components on each side of the road differently, i.e. "left surface", "right surface", etc.?
Exactly. We use a -LT and -RT suffix for point names and component names. We also add a -M for a median component or point that also has an outside complement. And a -F or -B for Front and Back for things like sidewalk edges. Sequence numbers are for the birds. It's hard to get consistent breaklines with sequence numbers. A tight naming convention makes transitions easier and modeling a smoother process.
