Hello, I am trying to cut plan sheets and am running into this issue:
When my named boundary length is smaller than the sheet width, the sheets place the model view justified to the left, when I want it to be in the center of the sheet. Is there a setting to justify the model view to the center of the sheet? I know I can do this per sheet by moving the model reference, but is there a way to set it up like this to begin with? See picture for issue. I need it to be in the center of the sheet as depicted by my red lines.
Thank you!
