I have a corridor that models a shoulder and ditch around the outside of a cul-de-sac. The corridor is made up of a linear template attached to an EOP linear feature with an active profile. I have a couple of Parametric Constrains that work as they should. I also designed two special ditch profiles (stored in the geometry file, but designed on the Bulb_EOP alignment, not on the ditch element itself.) I believe I added the point controls correctly to modify the ditch elevation in the corridor, but the dynamic XS viewer doesn't reflect the modified ditch profile. It looks like the point control is not being used. What am I missing? I have successfully used this template with other corridors. (The pavement surface is modeled in a different corridor.)
DitProN is for a ditch segment at the north side of the bulb, and DitProS is for a ditch segment at the south side of the bulb. These can be seen as the two heavy red profiles in View 5 (the profile view). View 7 shows that the special ditch profile point control is not being applied.
I'm not getting any follow-up help from Support so I thought I would post here.
Thanks for all of the suggestions. I had tried most of Matt's suggestions prior to posting, including rebuilding the corridor, but thanks anyway. It may help someone else.
What finally worked was splitting the corridor and geometry at the middle of loop into a north-side one and a south side one. This has been a limitation that in a loop situation you can't tell the point control to tell which station to pick. The workaround is to split it at the middle of the loop. Support said not to expect any change soon but there is a defect filed for this issue.
