what is a user defined network type? There is a whole bunch of logic built into each network type. I don't always agree with that logic and would like to change some of the default/delivered exceptions/behaviors. Is there some documentation on this? thanks.
Hello Jeff,
What program are you using for this and where are you seeing this? If this is not for the OpenFlows products (for instance, if it is OpenRoads Designer), this may need to be addressed by another team in Bentley.
Scott
it looks like everything is hard-coded. thanks.
Hi Jeff,
Please email me with your thoughts on what you'd like to achieve, as I have had a couple of conversations recently that might be relevant.
thanks,
Jon
