Models or DGNS which is better?
So we are still in the early days of adopting ORD in my organization. I was wondering if anyone has seen any performance difference between using multiple models in a single dgn VS using multiple DGNs?
our previous method was to create multiple DGNs and reference them as parts of the drawings. what I'm wondering is if theres a benefit to say placing all the parts of a design model in the same dgn and just using model spaces to separate them.
For Example a Detour.dgn would have the following as models:
-Detour Alignment
-Detour Corridor
-Detour Terrain
-Detour Earthwork
I was thinking the main benefit would just be reducing the number of separate files we generate but was also hoping that maybe it comes with fewer crashes and better functionality??
  • So i figured i would post an update after testing this. I did keep the geometry in a separate .DGN and tried to maintain earthwork and terrains in the same file under different models. RESULTS not functional....So apparently it can not handle updates to terrains where the corridor and the terrain are in the same DGN file. At First everything was fine and worked as normal but eventually the file lost connection to the terrain. to the point that the terrain was Schrodinger's Cat. it was still there and had properties but it didnt exist according to the project explorer and refused to update. I also found that MultiModal Views doesnt work well in those environments most probably because the vba scripting is using "default" as the main start command.
  • to add a twist to this....
    what are your thoughts on drawing files and sheet files ?
    generally when a sheet is created for a plan or profile, the process creates a drawing model and a sheet - should these all be separate files as well ?
    Timothy Hickman
    Main: 877 627 3772|
  • Don't get me started on Drawing models...I understand the purpose, but I am not a fan.
    My personal thought is that drawing models and associated sheets should be in the same file. Files should be separated for "type" of sheet (plan, construction detail, erosion, grading, etc.) and on long projects, they should probably be divided into workable segments.
    My practice over time is to have one sheet per file, all referencing a single "container file" for their type, just because that makes it easiest to throw bodies onto a project in a time crunch. If all of the Plan-profiles are in one file, only one person can work on them. If each sheet is its own file, I can take sheets 1-20, Mike can take sheets 21-40, and Sherry can take 41-58. It's not ideal (I love the idea of having all the sheets of one type as models so you can just work your way through) but getting the job out the door often requires solutions that are less than ideal.
    Of course, I'm still working in SS10, so I haven't had any daily-use, project-driven pratice with the ORD Way. There are already things I don't care for - cross section drawings/sheets sound particularly heinous after decades of just being able to click through them in one file with Geopak and InRoads. The introduction of drawing models due to the lack of actual graphic profiles or cross sections is going to give quite a few people fits. I'm also leery about the saved view idea, because of the number of ways and times they need to be updated; I'm more a fan of a straight-up reference attachment.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Another concern is where the Annotation Groups are placed when exporting sheets out to their own files.  Those dgn files (sheet and drawing models) created by the software will not have a "default" model and even if you did throw those out to a specific dgn file, the default is ignored and the Annotation Group is still pulled from that original default model that was used during the process and no access to copying from Standards DGNLIBS. (Named Boundaries can be referenced into any dgn).  I've heard some workflows have dgn files containing only Named Boundaries.  So, the question comes up, what if an Annotation Group needs to be added or copied for edit? What process would you use to update the Annotation Group apart from rerunning the sheets?  The Drawing Model Annotation tool is also limited to that one dgn (it will not go out and scan through and remove annotations or place new without the user going into each dgn file).  At the end of the day, the only benefit to throwing sheets out to independent sheets is the ability to place text in their drawing model.  The Batch Process may have functionality to assist for those able to write command files to run the necessary tools and sequence of options. Also note that the software creates Saved Views when creating the sheets.  Those Saved Views exist in that original file.
    ORD 2021 R1 (10.10), 2022 R1 (10.11.00.115), 2022 R3 (10.12.02.04) | MS 10.16
     Bentley Accredited Road Designer Bentley Accredited Road Modeler
  • Concur with MaryB and she is quite correct on the xsections in ORD being a handful and worse. you really cant do alot of measurments in regards to the surfaces because its somehow not a line? but a terrain and thus you cant flood measure areas on xsections or pattern anything. updates and annotations are not terrible but be prepared for a lot of pre-work to get annotations functioning. also you can do reference attachments but it has to be xsection by xsection. currently we are having issues getting the xsections to have even start elevations at the bottom of the cuts (ie 870 not 871,877, etc) it wants to base the start of the xsection on finished grade and not round up or down to even intervals.
    As for plan and profile sheets we are looking at limiting them to 4 sheets per DGN for throwing multiple people on them.
