What can we do when we get a "The file has more than one utility databases. This is not recommended." Is there a way to delete one?
I'll submit a ticket, I'm just wondering if anyone knows..."
thanks,
-jeff
Hi Jeff,
In previous versions, it was possible, although probably not desirable, to create a utility database for each 2D design model in a design file. This message was added to alert you to that. We've added the ability to delete a utility database from a model in the next version.
Indeed. 2022 R2 allows one to remove drainage databases.
Mark
Hi Jon,
if the file is losing the embedded drainage Database, can we re-add?? if yes, what is the workflow?
