I am working in ORD 10.10 and trying to create Cross Sections with EAV Volume Earthwork Annotations.
I am reusing the same named boundaries from a previous EAV run and have updated the corridor since.
Is there a way to refresh or update the EAV XML Fragment data that is embedded within the Name Boundaries to the most current EAV Volume run data without deleting the named boundaries and starting completely over? My Cross Section annotation tools are kind of janky so there has been a bit of "old school" cross section annotations that I will be loosing here if I have to delete these named boundaries.
Matt:
I do hope that you do not think that I am condescending, but I am so impressed with your growth throughout these years of learning ORD. To tell you the truth. I have always recut cross sections at times like yours, but I am interested in seeing if others can answer your quite solid question. Keep on questioning as so many of us should!
Best Regards,
Mark
Isn't the whole point of the 3d cuts to avoid recreating sections every time? I'd love to know the answer as well. I would have thought that the the XML data was rewritten on every run, but not sure...
Mark S.:
My thoughts also. Appreciate your input on this as well!
