I received a workspace from TxDOT but it needs modification. I am wanting to be able to draw (for example a easement line) in the Geometry Builder, however while the feature (ES_Easement) is in the Feature Definitions/Symbology and the Template, it is not located for use in the Feature Definition Tool. Is there a way to add it to the Feature Definition Tool? I have searched on the forums and on Bentley Learn and cannot find anything. I'm currently using ORD 2021 Release 1 v.10.10.01.03 Below is my example.
Located here:
Not located here:
Stephen, first the Element Templates and Feature Symbologies don't matter. The GB is only looking for Alignment or Linear Feature Definitions. Second, you inserted graphics above don't show enough of the FD folder structure to know if you are even browsing into the same folder / subfolder structure. I've been using the GB quite a bit lately and have not experienced what you are describing. ... I would first make sure that you are browsing into the exact same folder / subfolder location.
Hi Mark, I am fairly new to ORD (3 months in) and I am unfamiliar to the folder structures for ORD, I believe the folder structure for me is C:\TXDOT\CONNECT\Configuration\Organization-Civil\TXDOT\Dgnlib\Feature Definitions all of my dgnlibs reside in there for the Aligment and Linear Feature Definitions to read. They (dgnlibs) have been updated with new information, but I am pretty sure that this is not what I am looking for. Do you have an example of where I should be looking?
I'm not talking about the configuration ... I'm referring to the folder / subfolder structure of the Feature Definitions when you are browsing to them within the software drop-downs. From your snapshots I can't tell if you are even browsing to the same folders. (Maybe you are.) In your first graphic above you show the FDs in the "Easement" folder. Then in the GB you show the FDs in the "Right of Way" folders. Are you expecting to find the same FDs in different folders?
I showed different folders, in GB I was intending on illustrating that I do not have the option to choose the Easement Line. Is there a location that GB pulls the information from?
Missing Easement option, I would think it would be here.
