[ORD 2021 R2] Undo Command Causing Crashes
Even when undoing a simple command like drawing a line, the program grinds to a halt and either crashes or takes an unusually long time to process. Does anyone else have this issue? The undo command is convenient and I've grown accustomed to using it, but should I avoid it altogether in ORD or is there some setting I am missing?
Parents Reply Children
