Hello! I am trying to apply a superelevation to a divided highway. I have attempted this with 2 different superelevation files with the same result. The left side of the highway will not super. I have superelevation in the file and the Eastbound lanes will super, but the Westbound will now. Points are all Superelevation flagged. I even attempted to wipe clean the left side and re-enter all information.
Wow, that is a LOT of superelevation entries in your corridor objects. Why do you have so many?
The most common reason for point controls not working is a station range overlap of some kind. I would make sure that is not the case. It could also appear you do not have any overlap due to decimal precision display.
Marc
