HI all, when creating a new corridor in ORD with a specified template drop the corridor wont follow the baseline profile, and generate like a kind of chamfer at the deviation point, Thank you in advance.
You either need to add key stations or change the horizontal stroke tolerance, I believe.
This requires changing the corridors "Feature Definition" to one that has the critical sections at horizontal and vertical cardinal points turned on and some densification on horizontal and vertical curves.These settings can be found here:
