Conduit does not meet minimum slope constraint (but it does!!)
I'm running SewerGems inside OpenRoads and it gives me a warning
"Conduit does not meet minimum slope constraint"
But as you can see below, my "Default Design Constraint" is set to a minimum of 0.0046, and my conduit has 0.005
Anyone has ever seen this happening? Thank you!
  • You can set different design constraints for different scenarios, so have a look at the properties of the active scenario, see what Design Alternative it is using, and check whether the minimum slope in there has a different value.
    You can also set a Local Design Constraint in the properties of an individual conduit, to override the default design constraint values, so this is another thing to check.
