I have a file with an active corridor in it, but the corridor does not show in the project explorer. I can't make any changes to the corridor. Is there anyway to fix this? We are about to turn in final plans so recreating the corridor would cause many issues. See image from the corridor file and exception log linked below.
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5922/2273.Screenshot.png
/cfs-file/__key/communityserver-discussions-components-files/5922/Exception_2D00_20220805_2D00_121608.log
Have you tried the Reattach Corridor tool?
colliersengineering.com
Does your corridor have external corridor references? If yes, check to see if the references have been changed in the control file. Kevin O'connor would suggest this ;).
Yes. No dice.
The corridor cannot be edited at this time. The screenshot came in very tiny but in the Project Explorer menu the corridor does not show up. Kevin was solicited for advice before I posted here of course.
