In this file, I have referenced in 3d linear elements that represent the ROW (yellow). The ROW profile has been assigned by the surface terrain and when I use the civil analysis tool, the correct elevation is shown.\
But when I open the dynamic cross sections, the ROW line is shown at a zero elevation along every station of the corridor.
Has anyone dealt with any issues like this, or know what might be going on?
Was this issue ever resolved? I am having a similar issue but my R/W line does not show correctly on the dynamic sections (it is just a dot but it is coming in at the correct elevation). The profile for the R/W is based off the active terrain and I set the profile to active.
Aaron:
Do you have an object- a cell probably- assigned to be used in the dynamic cross section area of this linear feature? The "dot" you have mentioned is probably just a placeholder here, but it could be a cell. If you zoom as far in as you can into this area, is it still just a "dot"?
Mark
Mark, thanks for the reply. I may have to double check my workspace to make sure there is a cell assigned to the R/W feature definition.
