Does anyone know if its possible to make the Terrain Model by Graphical Filter tool honor a fence? I want to create terrain models for features only inside a fenced area. No matter what I do when using a graphical filter, it pulls in everything from the entire dgn.
Thanks in advance for any help.
Jason
OpenRoads Designer CE - 2021 Release 2 Update 10
Version 10.10.21.04
Hi Jason, I don't think there is a way only with the graphical filter method. But after the terrain is created, you can draw a shape and use "Create Clipped Terrain Model" under Additional Methods. This will rule it to the original terrain, but if you want to unlink it you can select "Remove Rule."
Hi Jason, I would add the fence as a boundary, the problem is that you will have multiple fences that is not part of the extend of the terrain. A manual process as per Kristina's response might be the best solution.
Senior Highway Design
ZUTARI SOUTH AFRICA & AURECON
Kristina certainly has a great solution here. There are many other methods, many of which have extraneous issues, though.
Best Regards,
Mark
