Does anyone know if there is a way in level manager to search for a level. Say for example there is a level called RD_ROAD_TrafficSign. But, I did not know this and wanted to search for "sign". Is this possible? If not, it should be.
Marc
You can use the Filters to search for levels. Untitled Filter allows the user to search for specific words.
To Define a Filter "on-the-fly" Using the Level Display Dialog (bentley.com)
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Answer Verified By: Marc Bachand
I think the "all levels" option will give a similar result in allowing the searches to be done on the columns as well - at least that is what it seems to be doing for me.
Timothy Hickman
Main: 877 627 3772|
Thanks Mike. That is an odd way to make that happen....but it works.
