Visualisation Specialist Trying to Understand Exporting Issues.
I recently jumped to a new role doing infrastructure visualisation and was given a large highway project in ORD and OBM to export and eventually run through a renderer.
After getting through the huge host of issues exporting from OpenRoad entails (Did you know if your geometry is to far away from 0,0,0 it breaks the exported geometry). I've finally hit the barrier of exporting clean geometry from an OBM file that not even the old hands can figure out.
So after my life story my questions are:
- Why are barriers and rails treated differently to the rest of the geometry when exporting? No matter what I do or how I export any roads or bridges with barriers or rails disappear on export.
- Why Can ORM export IFC but OBM cannot?
- Why does breaking up the barriers with "Drop Line Style" mean "some" of the barriers and railing elements are exported successfully.
Notes:
- I've been trying to export out using OBJ, FBX, DXF, DWG and IFC all with the same results.
- Opening Up the DGN in another , non-bently program also creates the same issue.
- I'm a very new user of ORM and OBM as I only started 2 moths ago.
I'm utterly lost at this point, any help or advice would be greatly appreciated
Parents Reply Children
