Is there any way i can delete dynamic cross section view or change my view to Default 2D. I have already tried using view attributes .
Please help.
Thanks in advance
Try key-in "geometry dynamicsection deletedxsviews"
communities.bentley.com/.../dynamic-cross-section-view-is-blank-and-missing-3d-components-in-openroads-designer
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Hi I have tried this but still in view one somehow i am not getting my Default 2d view instead always getting dynamic cross section view. If required i can share my file
Click in View 1 and then use CTRL+B on the keyboard to open the view attributes dialog where you can define the model to display at the bottom of the dialog.
Thanks.
Thanks. Here i have attached image showing before key-in and after applying key-in. But after applying Key-in i am not getting 2D view instead dynamic view with some distorted dynamic cross section. Please have a look if you understand what is happening. Kindly reply.
Thanks and regards
Deval
