I set my Civil Accudraw to my alignment, then after I use the command, it switches to the line I am placing. I have to continually use "O' to get back on the alignment I want. Is there a trick to keep it on the one alignment?
No trick as far as I know (Scream and holler, run in circles), but I'd appreciate hearing other's ideas. What appears to be happening is CA is trying too hard to be helpful. For example, "hey he drew a line, I bet he wants to use that line for stationing" ; "Hey he picked a curve, now he wants to use the curve for stationing."
Robert Garrett Senior Consultant
www.envisioncad.com
Hi Carlton, have you tried turning off "Floating Origin" under Civil Accudraw settings?
Thanks.
I don't know, but I would settle for Civil Accudraw staying on profile settings when I am in a profile model. Instead it either refuses to toggle on or off, or has settings more appropriate to a plan view (i.e. station offset vs station elevation).
