Good morning,
Hi, I have an alignment with station from 0+000 to 10+000, and I also created profile for this alignment also.
Now I only need the alignment with station from 0+000 to 3+000 and I want to delete the station from 3+000 to 10+000.
How can I do that without losing the created profile from 0+000 to 3+000?
I'm using OpenRoads Designer CONNECT Edition - 2020 Release 3 - Version 10.14.04.04
Thank you very much.
Parker
If the alignment has no dependencies then it may be easier to create a new alignment by using single offset partial from 0 - 3000 and then copy the vertical. If the alignment has dependencies then the element ID must remain the same so I would look towards tools like Geometry Builder Edit & Delete vertex to remove PI's between 3000-10000.
Answer Verified By: Tuan
In continuation with Paul's suggestion, please refer to the following link which reflects the first method:
Demonstration Video
Depending on dependencies you can use the MicroStation Delete vertex command to delete components from a complex while maintaining the original complex. Start at the ending element and snap to the end point with this tool. Then continue downstation.
Marc
Thank you so much with your help.Paul Cusack Rohith M Marc Bachand
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
