I clicked on my horizontal alignment and hit "create profile model." Then I clicked the view I wanted to put it in. I was adjusting the size of the window and I accidentally clicked in my first window (view 1). This made my profile appear instead of the road I was working on... which is a problem. I can't undo it because ORD doesn't see that as an action or something (the undo arrow is grayed out because that was the first change I made). How do I get to my main road design? There has to be a way, but I'm still new to the software, and I don't know what it is.
Okay, I was looking through old forums for an answer and I found one! The answer was to change the model from profile to default on the view attributes window for View One. There are a couple of different ways to get there, but I usually click on the button on the top left corner of the window and click "view attributes."
Answer Verified By: Grace Eastman
