I am using ORD CE 2021 R2 and am having an issue with the cross section elements showing up as solid (fill) shapes that print solid black or gray. The element template only defines the level which should have a line weight of 0 and a material. I have no idea where the fill shape is coming from or why it prints.
Any suggestions?
Are you able to select the elements and change Fill from Opaque to None?That's not a solution because it doesn't address how they came to be in the first place. I will leave that to more knowledgeable folks here.It would, however get your project out the door if time is of the essence.
MaryB
I'm having a similar problem on one project. The material images are being displayed on the sections like Jessica, plotting as a solid shape. I tried finding where its coming from and keep striking out.
This is because your 3d model View 1 is set to a rendered display style like Smooth. Try changing it to Wireframe and your section display style should change back to standard shapes.
Mark
Ah, yes. That was it for the most part. I had to update the sections from the saved view in order for the changes to be reflected. Thank you for the response.
Did you have to change each section drawing view to make it work?
