ORD 10.10.21.4. Anyone find a way to *consistently* get the cross sections to display hatch patterns? Trying to use the video link below seems to give inconsistent results. For instance, some components display the hatch while others do not.
communities.bentley.com/.../video-hatching-components-in-cross-section
I believe the issue is whether the section cut of a single component includes any voids/gaps. Is that what you are seeing?
eg, this is a single pavement surface template and does not hatch, while if it were a single shape it works fine:
Mark
Where you able to find a solution to this? I am having the same issue trying to add hatching to certain component. I did this for a different level/component and had no issues, not had to add an additional element that needs hatching and am having inconsisten results when applying the hatch. Sometimes it works sometimes it doenst, even on the same cross section. I created the Component in the template the same way each time.
I am not able to get a component built as an overlay/stripping component to display any hatching, but components built as constrained components seem to work.
