Hi all,
This is my .dgn file: Example_Stationing.dgn
I have copied an annotation from original annotation (“Alignment 100-10”) in order to create a new annotation (“Copy Alignment 100-1”)
After that, I edit offset value of ““Copy Alignment 100-1”” (such as: station label major), my issue is the software automatically change the offset value of original annotation into the offset value of copy annotation.
I don’t understand why it is happening.
I am using OpenRoads Designer CE - 2021 Release 2 - Version 10.10.21.04, Using RealDWG 2022
Could you please help to solve this issue.
You copied an Annotation Group. That copies the name of the annotation group, but it's still using the same individual annotation definitions that makes up the original group. If you want one of its annotation definitions to be different, you need to copy the definition and use the copy inside the copy of your annotation group.
Answer Verified By: Tuan
Thank you so much with your help,caddcop
Following your instruction, my issue was solved exactly.
Tuan
(Version 10.10.21.04)
Experience. In other words, been there, done that.
