Guiderail point placed in template, not showing up in 3D model
Good afternoon,
I've placed a template point for guiderail in my roadway template, and set the feature definition of the template point to what I believe to be the correct feature: Linear/Template Points/Guardrail and Barrier/TL_Guardrail_Single_Sided_R.
In the Dynamic Sections view, the guiderail appears.   However, in the 3D model, only a line along my hinge point appears in the model, corresponding to where that template point is.  The 3D guiderail does not show up.
Attached are screenshots of the library feature definition and feature symbology properties for the guardrail point.  I think it all looks correct?
Any help would be much appreciated!
Thank you,
Larry
