Good afternoon,
I've placed a template point for guiderail in my roadway template, and set the feature definition of the template point to what I believe to be the correct feature: Linear/Template Points/Guardrail and Barrier/TL_Guardrail_Single_Sided_R.
In the Dynamic Sections view, the guiderail appears. However, in the 3D model, only a line along my hinge point appears in the model, corresponding to where that template point is. The 3D guiderail does not show up.
Attached are screenshots of the library feature definition and feature symbology properties for the guardrail point. I think it all looks correct?
Any help would be much appreciated!
Thank you,
Larry
Yes, I checked and Line Styles is on in the view attributes.
If create horizontal geometry then assign an active profile to it with the same guardrail feature definition does the linestyle appear in the 3D model?
As a test you might also change the feature definition on the template point to something else to see if the corridor 3D feature updates. If it does change, then modify the feature definition on the template point back to guardrail.
I'd also check that all your levels are on in the 3D model.
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
I tried that, and it just shows up as a solid line, just like it's currently doing in my 3d model based off my template. FYI see below, attached is how it appears in the model. Just a line showing up corresponding to the guide rail point in my template. I checked and all levels are on.
Just to confirm, do you have a 3D linestyle defined in your feature symbology?
It appears to be set up correctly. Here is what the feature symbology property box looks like for the guiderail template point.
And here's what the element template property box looks like for the guardrail element
Looks to be exactly the same set up as what I've seen in videos posted on line by bentley on the guardrail feature definitions.
