After exporting the 3D models from OpenRoads or OpenRail Designer, when I explore them in BimCollab or Navisworks, some of them doesnt't have right location. In BimVision and Trimble connect everything is okay. Do you know how can I deal with it? I used export all schemas what are available IFC4, 4x3 and 2x3 and have the same results.
AM
Hi Andrzej Modrzyk , did you find a solution or a workaround for this problem? We are also experiencing the same. Also by first uploading the files to iTwin and exporting them to IFC does not solve the problem, exact same results.
If the coordinates were any logical, maybe we could solve it. But the GPS coordinates are completely random.
Hi Jasper, what version of ORD are you running? 2021 Release 2 resolved quite a few IFC schema issues.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Hello all,
I am going to take advantage of this topic as I am totally lost about what is going on with the IFC export of our dgn files.
Our design files are in US feet working units, I got a roadway created by ORD and bridges created by OBM, once the bridges were modeled, I created a mesh for the bridge elements to be able to export them to IFC. I exported the master file to IFC, from there everything looks like to be ok, I opened the IFC file with a free IFC viewer (BimVision), and each model is aligned to each other.
I started realizing about some discrepancies when I decided to create separate IFC files for the roadway and the bridges (superstructures and substructures). First, as IFC files I attached them all together in the BimVision platform, the models are randomly separate in the space, why is this happening if each model is being exported from the same site, the same coordinate system? This means any time I export a model to IFC I will need to georeference them manually to the right site?
Then, I attached the same IFC files back to my dgn and it is happening the same, they appear to be in different location and smaller than my original dgn models. To georeference them right I applied a scale of 10.763867382 and moved it manually. It does not make sense to me, I though it would keep the same geolocation and dimensions in the IFC file as well.
So, to investigate deeper I decided to check the surface and volume of an element from the dgn and from the IFC viewer. Attached there are some screenshots to show you what is happening from ORD, OPB, BimVision.
Is ORD by default converting the USfeet working units to meters when the dgn is exported to IFC?
Also, I published the model to Itwin following previous advices, but working units as well appears to be in meters.
I am very confused so any help or advice will be much appreciated.
I am using OBM Release 2 Update 12 10.12.1.83 and ORD Release 3 Update 12 10.12.02.4
Thanks for your help!
Jonatan
Hi Jonatan,
Can you share a sample IFC so we can have a look?
Hi Mark,
Thanks for replying. Here is a compressed IFC file.
Testing IFC.7z
Have you had a chance to have a look at it?
I couldnt see any issues with the IFC. Do you have any more info to demonstrate the issue? Is it when the road and bridge are exported seperately you see the problem? Do you have the dgns to compare?
