After exporting the 3D models from OpenRoads or OpenRail Designer, when I explore them in BimCollab or Navisworks, some of them doesnt't have right location. In BimVision and Trimble connect everything is okay. Do you know how can I deal with it? I used export all schemas what are available IFC4, 4x3 and 2x3 and have the same results.
AM
Hi Jonatan,
Can you share a sample IFC so we can have a look?
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Hi Mark,
Thanks for replying. Here is a compressed IFC file.
Testing IFC.7z
Jonatan
Have you had a chance to have a look at it?
I couldnt see any issues with the IFC. Do you have any more info to demonstrate the issue? Is it when the road and bridge are exported seperately you see the problem? Do you have the dgns to compare?
