I need to shift my vertical alignment for one road to match where it meets another one that's already been designed by someone else. Can anyone help?
I'm using Open Roads Designer CE - 2021 Release 2.
Also, does anyone know what cached geometry means? Because I keep getting errors that say I may have outdated information, and I don't know why. It says my data is from a cache that can't be found...?
And is it normal to have two 3D models of the same name?
That looks like that Default-3D model is attached twice. Since that's the reference dialog, you don't have two models with the same name, you have one model attached two times.
MaryB
You may be seeing this if you have a 3D Cut in a profile view. Either refresh the 3D Cut or delete it if you don't need it anymore, and that warning will likely go away.
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
Thanks. I think that was the problem.
