Is there a way to deactivate the Drainage and Utilities Design once its loaded into a basemap? I accidentally opened it in a file I didn't want it in and now it loads every time I get into my road modeling file. I have a different drainage basemap, so I dont need the drainage/utilities to load in my road modeling file.
Matt - If you have "branded" your file as a D/U file, it will actually create additional databases in your DGN file for support of the D/U modeling and analysis. It's my understanding that this cannot be undone. Beebe Ray may have a additional thoughts on this issue.
Pulling a file from the backup may be the best fix.
Matt:
Chris is correct here; that is, it cannot be undone. I believe- I have heard- that the next version of ORD will allow one to undo/ delete this additional data.
Mark
Yep, mentioned here:
communities.bentley.com/.../file-has-1-utility-databases-how-fix
