Sheeting a single alignment that has two pgl profiles
I am working on a curved roadway the has a single alignment but has two separate proposed profiles.  The first profile is the proposed grade line for the Eastbound lanes and the second profile is for the westbound lanes.  These profiles are offset from the centerline.
To create my profiles, I have stored them on the centerline alignment.  To know were existing ground is at the offsets, I created projected existing ground profiles that were projected from my PGLs to the centerline.  The reason I did this was to store my profiles with the centerline stationing.
I would like to show my two profiles on a double profile sheet (the top profile will be westbound and the bottom profile will be eastbound).  No matter what I do, both profiles show up on both views.  Is the only way to do this would be by putting the two profiles on different levels and shutting one off on each view?  Is there a better way?
Thanks so much for any help,
Dennis W
  • Another reason I want to store my PGL profiles on the centerline alignment is for the annotation of the profile.  If I were to store the profile on my offset alignments and then project it to the centerline, I end up with a chorded version of the real profile and it wont annotate vertical curve info (because its now a streched and skewed chorded version of the real profile).  This projected profile works great for modeling but not showing the contractor the actual profile info.
  • I agree with this.
    We are required to show a number of profiles, and they all need to be annotated off the baseline. For the plan set we are required to produce, it doesn't matter that I am displaying the profile of the left EOP, it needs to be stationed along along the BL.
    As an example, I consider a ditch line profile. We know that the ditch line will not be exactly as long as the baseline because, when the baseline curves back and forth, the offset ditch line will be longer or shorter than the baseline depending on whether it is on the inside or outside of the curve. The people reading my plans do not care. The ditch starts at station X+XX and ends at Y+YY, and the grade shown along the ditch needs to be based on that algebraic station to station length, not the actual length of geometry. I also need straight line segments, with defined PVIs - not a fuzzy projected profile. Let's make this even better, because I often need to show ditch profiles above or below datum for plans readability.
    It sounds as if, to properly display this type of design data on my sheets, I need to define all of these profiles on the baseline. But doesn't that defeat the entire purpose of modeling?
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
Reply
    MaryB
