Equal Space Points tool issue
I'm attempting to place a series of 2D points using the Equal Space Points tool and upon doing so, keep receiving the "Element off design plane" error message immediately followed by the all too common program crash. I noticed it created a 3D model in my dgn even though I have the "Want 3d Point" field disabled. I ran through the motions a number of times to ensure I wasn't accidentally attempting to generate 3D points and can't figure out what's causing the issue. Below are screenshots of my tool settings and Power InRoads version number. Any help is much appreciated. Thanks
  • What are the coordinates of these points?
    How far away from the center of the design plane are they?
    Are you using a GCS or local coordinate system?
    How are your design file working units defined?
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Thanks for the quick response Mary. I can track down answers to all your questions, but one thing I should've mentioned previously is I'm attempting to place these points in the middle of other design geometry that was created without issue. I'm probably overlooking something but it seems illogical that these points could somehow be off the design plane but everything else that surrounds them is not. Thanks again
  • Below in italicized text are my answers to your questions. Thanks again for your help
    What are the coordinates of these points?    The line I'm looking to place them along begins and ends at the following coordinates:
    Begin 3,123,246.4767,10,084,647.1596
    End 3,122,975.5466,10,084,141.0038
    How far away from the center of the design plane are they?     I'm admittedly a rookie when it comes to coordinate systems but believe the coordinates noted above are based off the global origin so I ran the "GO=?" key-in to determine it's location relative to the design plane center and received the following: The Global Origin is offset -2147483.6470, -2147483.6470 from the design plane center. Crunching some quick numbers, I believe the beginning of my line is 975,762.8297, 7,937,163.5126 from the center of the design plane
    -2,147,483.6470+3,123,246.4767=975,762.8297
    -2,147,483.6470+10,084,647.1596=7,937,163.5126
    Are you using a GCS or local coordinate system?     There's no GCS defined so I'm guessing the answer is a local coordinate system
  • In earlier version of MicroStation, the design plane/cube was finite. To get some coordinates datums to fit within the design/plane/cube many workspaces used shifted global origins. This is generally no longer necessary but legacy files are often used which keep using and preserving these settings. However, changing the global origin midstream is not a trivial task and can screw up existing graphics .
    Can we assume you are not working in a V7 file format? And if you are entering coordinates, you should not use commas to indicate thousands and the software is not designed to recognize that format.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • Thanks for the info Caddcop. The file I'm working in was created from a seed file posted on TxDOT's website a few years ago. I'm assuming it's V8i based but am not sure how to verify. And yes, I only included commas for the coordinates in my reply to make them more legible but haven't actually input coordinates with commas in microstation. Thanks again
Reply Children
  • You can try moving your path element to something like 1000,1000 and seeing if the tool works on it there. If it does, then there may be an issue with your elements being so far out. The V8i plane is infinite, but there are several random tools that don't work well very, very far away from 0,0. If distance is the issue, folks here may be able to help you find a workaround.
    If that doesn't solve it, there's something else going on...
    Did you clear out your Geopak RSC files? I believe they are saved in the C:\Program Files\Bentley\GEOPAK\bin\ directory. That might not be it either, but it could be. Bad RSC files cause unusual errors.
    MaryB
  • Thanks again Mary, unfortunately moving the line closer to 0,0 didn't resolve the issue. I'm working in Power InRoads and was wondering if you knew where those resource files reside? Thanks
