Hi All,
Is it possible to combine all cross sections in one xref and all long sections in one xref as well, particularly in model space?
like this below image i got from (+) Create Multiple Cross Sections In Single DWG File using Final Drawings Manager - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities
this link.
is there any solution to create Multiple cross sections in OPENROADS.
TA
Hi Aparna,
Please follow the below process:
1. For Single Long section - https://www.youtube.com/watch?v=jk1BLHIwfkc
2. For Cross sections in Single model (Available in training and examples workspace and Training metric workset) -
All the drawings are created in Drawing/sheet models. You can make any changes to annotation in drawing models if required then you can export the same into other formats
Rohith M
I would like to see ORD include a tool to navigate between cross sections when they are drawn into one drawing model.
While much of the annotation can be automated, there will always be the need for individual notes on certain specific sections, as well as the ability to review and assess sections in bulk. The ability to be able to navigate efficiently between sections, or to any specific section as desired is incredibly valuable. Geopak Cross Section Navigator was invaluable, with the InRoads analog a close second. Even if these are not needed specifically for design, they are very helpful.
MaryB
A Cross Section Navigator was added in the 2021 R1 / 10.10 release. https://www.youtube.com/watch?v=R9osG9mszPM&list=PLnJUnxLwu_N7ThhmfkTRw2WShEWT46GCO&index=8
Config variable CIVIL_CROSSSECTION_NAVIGATOR_ENABLE_DRAFTING_TOOLS = 1 will enable additional drafting tools similar to what was available in GEOPAK. https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/216034/ord-2021-r1-civil_crosssection_navigator_enable_drafting_tools-info/658189
Matt
Awesome!!
I can't really read this image to see what the setting is to generate cross sections in a single model. Also, how could we copy this option from "Training and Examples" into our own workspace?
