What is the most efficient way to match feature definition quickly from one existing element to another existing element?
Can you help to guide me how to quickly match feature definition from one existing element to another existing element? Instead of opening element property and selecting the feature definition.
Thank you so much.
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
  • Tuan,
    Use the Match Feature Definition tool to match the "existing" element, then use the Set Feature Definition tool to change the desired element(s). Works very similar to SmartMatch and Change Attributes in native MicroStation.
    Eddie Giese, PE
    Production Manager | Senior Roadway Engineer
    Licensed in FL & PA
    ACEC FDOTConnect Instructor on behalf of FDOT
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
    premier-scholar-badge road-designer-badge
    Answer Verified By: Tuan
Reply
  • Tuan,
    Eddie Giese, PE
    Licensed in FL & PA
