Morning All,
I'm using OpenRoads Designer, 10.10.01.03
Has anyone found how to increase the number template drops/strokes along a Linear Template for both linear straightaways and radial sweeps around corners? I have changed the Configuration Variables: CIVIL_DEFAULT_CURVE_STROKING & CIVIL_DEFAULT_LINEAR_STROKING but there hasn't been any affect with changes to these variables. All I get are template drops at the start station, end station, and the end point of a segment.
Thanks for your time and help, have a good day,
Ok do this: create a new 2D files, once opened just hit the "set active terrain" then right click on your view and choose view - 2 views 2D and 3D
Now in your 3D windows/model draw or import your lines and try everything that was mentionned above
maybe also start a proper training on openroads
Will, let me know if you still need some help with this. Give me a phone call if you do.
100% Mark! So many who are more familiar with working in 3D or assume "3D Model" indicates 3D only miss this particular workflow requirement of ORD. It seems like Bentley should have a clear path or hard limitation (warning dialog) to what's attempted in a 3D file when it comes to these ORD tools and workflows.
With that said, I noticed Grot is working in an area of an abutment by the file name.
@Grot, I know this is a leap and would take the workflow out of the ORD toolset, however It may be worth looking into the Drawing (workflow dropdown) Constraints tab to develop 3D by "2D" constraints to draw in 3D. I know some minds work differently and that workflow may work better within your client needs. BentleyLearn instructions I've found are under one of the OBM pdf documents, despite those tools not being exclusive to OBM/OBD. https://learn.bentley.com/app/Public/ViewLearningPathWithMasterCourseExpanded?lpId=112428&mcId=103481 ( Actually, those constraint tools fall under Microstation within BentleyLearn... the OBM training document may be more applicable)
colliersengineering.com
