Justification of Named Boundary when making sheets
I'm cutting plan sheets for my firm. We have as Sheet Seed setup with a title block and the Drawing Boundary so it knows where to place the Named Boundaries during sheet creation.
Something I noticed is that when I make the sheets is that certain sheets have Named Boundaries that are smaller than the named boundary in the Sheet Seed. For example, the Sheet Seed might have a Drawing Boundary that's 500' long, but sometimes we need 300' long or 400' long Named Boundaries to fit between certain streets better. When making the sheets, the referenced Named Boundary always comes in justified on the left side of the Drawing Boundary in the sheet model, when I'd rather have it justified in the middle of the Drawing Boundary.
How do I make it to where it centers the named boundary in the middle of the Drawing Boundary?
  • Example:
    It centers it vertically but always puts the left side of the named boundary (at the centerline) on the left side of the drawing boundary, which gives me issues on skewed named boundaries like this one.
  • Due to the Named Boundary tool using Saved Views that apparently only have a bottom left origin, it's hard to say if there's another option available.  For areas like this that appear to need additional space, place boundaries into separate groups where the one between them would be in its own group (using a different length size seed).  The idea is to add all the named boundaries first, then go back and create the sheet portions later once the areas make sense. Placing them all in one group for sheet creation would prevent their named boundaries from using their designated sheet model seed. EDIT: You only need a separate named boundary group for that alternate seed to prevent someone from running sheets by the wrong seed. As with most ORD data, be as descriptive in these breadcrumbs as possible for others to follow your intent by having the separate group(s) (e.g. Plan 20 Scale - 300 clip length; Plan 20 Scale - 500 clip length).
    ORD 2021 R1 (10.10), 2022 R1 (10.11.00.115), 2022 R3 (10.12.02.04) | MS 10.16
     Bentley Accredited Road Designer Bentley Accredited Road Modeler
      colliersengineering.com
  • Is there any way to change the named boundary origin, or the named boundary "seed"/definition origin?
    Having to create a named boundary seed for every possible length permutation, and having to segregate sheet creation based on the length of sheet is just a whole lot of extra work. The entire sheet creation process seems so inflexible and invariable...And by the time we come up with all the workarounds and extra routines, is it worth it.
    (I'm sure it is, but it's a lot of work, and there's no obvious way to adjust on the fly)
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
Reply
    MaryB
  • This might be slightly off topic, but our 50 scales sheet seeds allow you to select them and change the scale and the lengths and offsets adjust accordingly. I did see it seem to get out of synch once, but starting over reset everything and it all worked great.
    But I agree that a center-horizontal justification for the sheet boundary would be a great option.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
