<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>OpenRoads Second Window Hides All Other Windows</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/235814/openroads-second-window-hides-all-other-windows</link><description>I have my Openroads set to open in 2 windows. From time to time the secondary windows dominates my screen and will not minimize. This becomes a problem when I click things like &amp;quot;Template&amp;quot; which brings up another window, because it is hidden behind my</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: OpenRoads Second Window Hides All Other Windows</title><link>https://communities.bentley.com/thread/732683?ContentTypeID=1</link><pubDate>Tue, 20 Sep 2022 08:07:55 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:f87f8bf1-0a4f-4255-b1a7-98441d5739bb</guid><dc:creator>Jan Blaasse</dc:creator><description>&lt;p&gt;I also use a setup using two screens, but have never had problems minimizing the windows. I am familiar with the Templates or Corridor Objects hiding behind one of the windows. For me the first option is simply to select the Templates in the windows task bar. If that doesn&amp;#39;t work, minimizing one of the windows will usually work.&lt;br /&gt;Another way is to move the hidden window to the other screen. You can use a windows keyboard shortcut to do that (shift + window key + arrow left or right). This will move the active window to the other monitor, even if you can not see or select it using the mouse.&lt;/p&gt;
&lt;p&gt;Not a solution, but if you use the second window only for placing pop-outs, you could disable the second window option.&lt;br /&gt;For me, a second window is only needed to place one or more views of the model. It is useful to arrange pop-outs, but not required to place them on a second monitor.&lt;/p&gt;
&lt;p&gt;Just to make sure, do you use any window manager software that maybe interferes?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
