Hi
I'm have Terrain that have a weird tringle with a point on 0,0,0.
If I hover over it the description for the point is named like Feature spot, for some reason a can't delete this point.
I already try to removed the terrain rule and do not work ether.
Someone know how I can deleted this point or the triangle created per this point?
Thank you.
I've never seen anything like that, so either log it with Bentley, or post the DGN file here with some directions to find this point so someone could potentially take a look at it.
Steven, you can upload the file at sharefile or one drive and send across the link here, if it is a heavy file. Or simply attach the file here
