I'm transitioning from InRoads to OpenRoads and I can't seem to find the equivalent command for Generate Transverse Feature (slope lines).
Is this feature available in OpenRoads and if so, can someone please point me in the direction of where it can be found?
Thanks!!
See this video https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/37274/video-side-slope-annotation
I have the same question as Jason and it has nothing to do with annotation. Transverse features control triangulation. Now ORD relies more on components than InRoads did but there are still times when you need a surface. Is there an automatic way to create transverse features while modeling to control triangulation or can it only be done manually?
We need InRoads Transverse Features!!!! I used them ALL the time!!!! ... what are we supposed to do now?
I was able to get the traverse feature using annotation to work, but obviously it won't project to a cut line.
I found a utility called Last Mile Utilities that works better. (Not quite as good as the old traverse feature command in InRoads) but it works.
Last Mile Utilities - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities
Dumb question - what do you guys use them for in Inroads? I'm not from an Inroads background (MX).
Mark
