One MicroStation Feature that is part of this new release is the Manage Configuration tool on the Initial Open File dialog box. While I have managed to add to New Configurations, I am apparently missing some settings as the settings coming from the Organization-Civil DGNLIB's are missing from the Project Explorer. This is also resulting in the "Bad things happened" dialog box if I try to access the configuration variables settings. So I decided to try the Configuration Explorer, but it only sees the delivered configuration using this technique.
Is there some way to get it to see the New Configurations and if not, what about command line switches to point a -debug session output at one or more of these New Configurations?
I'm trying to wrap my head around this too. I removed MicroStation CE U17 for this very reason, but am now having to deal with in the latest ORD.
Bentley has changed the way _USTN_CUSTOM_CONFIGURATION, _USTN_USER_CONFIGURATION, and MY_WORKSPACES_LOCATION variables work. This totally blows up how we managed different configurations in previous releases. You're now pretty much forced to use the Manage Configuration dialog. The configuration settings in this dialog is stored in a configuration.xml file in your user folder along with your personal.ucf.
I haven't seen any variables that control this location, or an option for a configuration.xml seed file. Trying to get standard configurations to all of your users is going to be a challenge. It would be nice if CAD Admins could create a seed file with this for all of their required configurations so it would be populated with the correct configurations the first time a user launches ORD. It would also be great if we could lock this file, or disable the ability to add/modify configurations so that users can't mess it up.
Rod WingSenior Systems Analyst
Folks:
I have not installed this new product yet, but what y'all are stating here is making me rather anxious. I will follow this thread with much consternation.
Mark
Well, I decided to use brute force and place it in the main configuration area. That works but I would still like to be able to troubleshoot other configurations using all the tools in my toolbox.
I am still learning the CONNECT configuration differences and unfortunately, I end up away from these for months at a time, maintaining our V8i workspace and then have to review and relearn when called back to the CONNECT world.
The worst part is that we really only work in ProjectWise these days, but have to export it to work with Bentley as we develop our revised ORD workspace. And when I get back a WIP version I have to start all over again.
On a side note, I believe I figured out what piece I was missing and did get my New Configuration functionality working. Now if I can do the same with some other Agency configurations so I can see what they are doing in ORD that we might want to implement.
Kevin van Haaren has done some detective work on this new configuration setup.
https://communities.bentley.com/products/administration/f/product-administration-forum/232341/msce-u17-manage-configurations-and-using-_ustn_custom_configuration-variable
Answer Verified By: caddcop
Here is what I have determined so far:
I have installed a couple of other agency workspaces using this tool. Some work as designed but others are proving to be problematic. The problematic ones are highly customized and the inability to create an MSDEBUG.TXT file is really hampering efforts to complete those installations. Similarly, the Configuration Explorer also appears to require some unknown settings to enable its use to evaluate these configurations.
