Hi all,
I recently installed ProjectWise Explorer,
When I open OpenRoads, one "ProjectWise log on" window always appear.
How can I turn off it?
Dose is affect my work in case I turn off the "ProjectWise log on in OpenRoads??
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
Hello Tuan,
To turn off ProjectWise log on Windows, please open pw.cfg, by default this file can be found here C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\config\appl
Uncomment line 14 from #PW_DISABLE_INTEGRATION_FROM_DESKTOP=1 to PW_DISABLE_INTEGRATION_FROM_DESKTOP=1.
Save file and close.
(1) How to turn off the "ProjectWise log on window" when open OpenRoads - OpenRoads | OpenSite Forum - OpenRoads | OpenSite - Bentley Communities
It will not affect your work if you have not integrated OpenRoads Designer with ProjectWise.
Purva Lakde
Answer Verified By: Tuan
Hi Purva Lakde.
Thank you so much with your help.
