How to export points to .txt file?
I feel like I'm missing something obvious. Looking for a way to export points to a .txt file with Point Number, Northing, Easting, Elevation, and Code as the format.
Also, it would be helpful if the linking codes would export as well. That way the linework would come in correctly to our field crews DC if needed.
ORD CE 2021 Release 2
Parents Reply Children
