I was adjusting some end conditions that included guardrail. It had been showing up as the proper line style before, but after editing the line stopped appearing in the 2d view. However, it is still generating the end condition because the guardrail shows in the 3D model. Anyone have any ideas on why it stopped showing the line all the sudden? (All guardrail lines, not just the one I was editing and working on). The line style doesn't even have any components when looking at the level display to see if the level was accidentally turned off somehow.
Which software, and which version are you using?
I can't recall the specifics, but there is a setting that will generate the line in 2D as well as 3D. I suspect you may have accidentally turned that off. I believe you can find more information with a search here - I've seen that discussed before.
MaryB
Here's the thread I was thinking of: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/234440/the-guardrail-is-not-displaying-in-2d-plan-view/727960#727960
I'm on ORD 2021 Release 2, I'll check out that thread below to see if I can get it to turn on. Thanks!
I had no luck finding the toggle that was mentioned. I used the search feature within ORD to try and locate it (the "feature definition set"), but no luck. If it's a back stage item, I have reinstalled the configuration and workspace information provided to designers in GA from GDOT. I've toggled various settings in the end condition exception to no luck
Hmmm...If it's in the feature definition, I think you can get there through Explorer. It's not going to be with the element, but I'm not sure if they are saved into the design file when they are used. If you didn't change the feature that may not be it.
Hopefully someone else will be along with more information. I'm still learning OpenRoads, so I know a few things to check but there are so...many...settings...
