I am trying to run the Station and Offset command in geopak and when I go to select my gpk file, I keep getting this error,
Has anyone every come across this at all? My payitem and utility command worked fine just before this and I can select the GPK file in the plan view labeler, so I know the GPK file is not corrupt. Any help is greatly appreciated!
Thank you
Eric,
You may want to move your post to the correct forum. The Civil forum would be best to get your answer addressed. https://communities.bentley.com/products/road___site_design/f/
Thank you! But this link leads to OpenRoads and I am running Microstation vi8 SS4
Okay thank you so much!
The forum has just been renamed, it is for GeoPak support as well.
